Cisco 851 Wlan problems
mdoyal
Community Member
I am unable to reach the internet using SSID TKCTS. Everytime it associates it is given a IP 192.168.1.103. However my fastethernet0 connection I have setup as DHCP and I get the correct ip 192.168.112.2. What am i doing wrong. attached is my config file... Thanks..
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ETH-WAN$
ip address dhcp client-id FastEthernet4
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto ipsec client ezvpn ASA
interface Dot11Radio0
no ip address
countermeasure tkip hold-time 15
encryption mode ciphers tkip
ssid TKCTS
max-associations 254
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid
wpa-psk ascii 0 XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 192.168.112.1 255.255.255.0
ip helper-address 192.168.1.5
no ip redirects
no ip unreachables
no ip proxy-arp
ip inspect DEFAULT100 in
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
crypto ipsec client ezvpn ASA inside
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip dns view ezvpn-internal-view
domain name-server 192.168.1.6
domain name-server 192.168.1.7
ip nat inside source list 112 interface FastEthernet4 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.121.0 0.0.0.255
access-list 100 remark SDM_ACL Category=4
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 112 deny ip 192.168.112.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 112 permit ip 192.168.112.0 0.0.0.255 any
no cdp run
5 Replies 5
Stephen Rodriguez
Create a BVI1 interface,and move the IP address from the VLAN to the BVI. Make sure to move all the commands from the VLAN interface to the BVI.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Thanks... I am not too sure on how to make the bvi. I am pretty new to this is thier a site I can go to for directions.
mdoyal
Community Member
I tried this and it did not work am I missing something. This also took my router down. I was unable to use SDM or CLI. Any suggestions?
ssid TKCS
authentication open
guest-mode
infrastructure-ssid
wpa-psk ascii 0 xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
station-role root
bridge-group 1
interface Vlan1
no ip address
load-interval 30
bridge-group 1
interface BVI1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
bridge 1 route ip
enable
that all looks rightl. You can't reach the router via CLI of SDM? can you get an address from the wired and wireless, and have internet access?
HTH,
Steve
I was given an address on the wirless side but it was a 192.168.1.103. I can us CLI but not SDM. My wired connection gives me the right IP 192.168.112.2. I am not able to reach the internet when the config with BVI is running. I have to revert back to the old config.
