Cisco 871 Wireless connection problem
mtyso1
Community Member
Hi I have set up this 871 router, and everything works fine except the wireless portion. The SSID is detectable, but no one can get connected to it. Please take a loot at the config and let me know what I did wrong.
b.hsu
Level 11
Level 11
The configuration looks good. I have a couple of questions here. Are the clients connecting to the 871 802.11g clients. Because in the configuration all the speed values are marked as require. This is because if yuou are using .11b clients you should not mark the OFDM rates as require. Also did you make sure that the VLAN configuration matches with that on the switch.
mtyso1
Community Member
Thanks for the good tip. I made sure that speed values are marked for 'enable' instead of 'required'.
chilinh
remove the sub-interface, and try the following
you can use the SDM to configure it,too.
(your "sh run int dot1 0" should looks as below; some commands are put by the SDM)
Karl
interface Dot11Radio0
no ip address
ssid Loan1st
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
54.0
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
mtyso1
Community Member
Appreciate your input!
I was wondering why the 870 User Manual showed an example with the dot11radio 0 sub interface.
I'll test this new configuration after I get back from my trip.
Thanks!
