Cisco and Symbol MC 70 hand helds
pndennie93
Is anyone having issues with Symbol handheld units just losing connection. I see no errors on the ACS server and cannot see that signal strength is an issue.
drolemc
Level 6
Level 6
What authentication mechanism are you using? Did you try disabling the authentication and check if you are still having issues?
