Cisco AP1140 not working correctly
ivovdheuvel
Hi All,
I recently aquired a 2nd AP1140, however when i configure it for WPA 2 it works inconsistent, a ping for example will work only for 33% of the time.
The same client has no issues with my 1st AP using WPA2, with the 2nd AP WEP works without a glitch.
Is there any tips what to try or debug to find out where the issue lies ?
Stephen Rodriguez
First thing is check are the ports. Make sure you aren't half duplex.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Steve the ethernet-port is full duplex, as mentioned when using wep it works fine..
Just did a test using the 2nd ap as a repeater, same issue when using wpa2
