Cisco APs management
mjohnson311
Visitor
I have about 12 access points (350 & 1200 series) scattered throughout our building. Just to cover conference rooms and such. I'd like to know the best direction to in order to manage these devices? Rogue AP detection?
mchin345
Level 11
Level 11
The WLSE is a hardware and software solution for managing Cisco wireless devices. The WLSE has the following major features.
1. Configuration and Firmware: The configuration feature allows you to apply a set of configuration changes to access points and bridges and to archive configurations. Using the firmware feature, you can upgrade the firmware on access points and bridges.
2. Reporting : Allows you to display reports for tracking device, client, and security information. Reports can be emailed, printed, and exported.
3. Fault and Policy Monitoring :Provides device monitoring for fault and performance conditions, monitoring of authentication server responses, and monitoring of policy misconfigurations.
4. Radio Management :Helps you manage your WLAN radio environment. All the device information is polled from the managed devices in your network. Radio Manager features simplify the deployment, expansion, and day-to-day management of the WLAN.
5. Site Management : Displays a graphical view of the WLAN environment.
For more information on the WLSE have a look at the following URL.
http://www.cisco.com/en/US/products/sw/cscowork/ps3915/products_user_guide_chapter09186a00803640cd.html
