Cisco Catalyst 9800-40 Wireless Controller SN
Sergey_Kobzar
Community Member
Hello !
Regarding the following:
NAME: "Chassis 1", DESCR: "Cisco C9800-40-K9 Chassis"
PID: C9800-40-K9 , VID: V03 , SN: TTM235208EX
NAME: "Chassis 1 Power Supply Module 0", DESCR: "Cisco Catalyst 9800-40 750W AC Power Supply Reverse Air"
PID: C9800-AC-750W-R , VID: V01 , SN: ART2337F8JN
NAME: "Chassis 1 Fan Tray", DESCR: "Cisco C9800-40-K9 Fan Tray"
PID: C9800-40-K9-FAN , VID: , SN:
NAME: "module 0", DESCR: "Cisco C9800-40-K9 Modular Interface Processor"
PID: C9800-40-K9 , VID: , SN:
NAME: "SPA subslot 0/0", DESCR: "4-port 10G/1G multirate Ethernet Port Adapter"
PID: BUILT-IN-4X10G/1G , VID: N/A , SN: JAE87654321
NAME: "subslot 0/0 transceiver 0", DESCR: "GE SX"
PID: QFBR-5766LP , VID: , SN: AGM1107JJHJ
NAME: "subslot 0/0 transceiver 1", DESCR: "GE SX"
PID: FTLF8519P2BNL-CS , VID: 0000 , SN: FNS10401GE1
NAME: "subslot 0/0 transceiver 2", DESCR: "GE SX"
PID: FTLF8519P2BNL-CS , VID: 0000 , SN: FNS1024H2AN
NAME: "subslot 0/0 transceiver 3", DESCR: "GE SX"
PID: FTLF8519P2BNL-CS , VID: 0000 , SN: FNS1024Q316
NAME: "module R0", DESCR: "Cisco C9800-40-K9 Route Processor"
NAME: "module F0", DESCR: "Cisco C9800-40-K9 Embedded Services Processor"
NAME: "Crypto Asic F0/0", DESCR: "Asic 0 of module F0"
PID: NOT , VID: V01 , SN: JAE24020S1V
Please, clarify, what SN is the main SN of the device?
Marce is right.  You need to identify the PID and Description first and then the info for that PID is what you need to reference. The 1st item shows you its the actual chassis or the device you want the SN from:
-Scott
Mark Elsen
 - Probably the first and or check , if also seen with show version
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
-Scott
