CISCO-LWAPP-CONTROLLER
Network Pro
I am trying to get this officeextend working.
I connected the ap and checked the H-Reap box and then officeextend and gave it a public ip. This public ip is NAT'd to the dmz controller on the firewall. (The dmz controller is 5508 running code 6.0.199.4)
I have connected this officeextend 1132 ap to a broadband connection and this gets an ip of 192.168.1.23 on its fa0 interface. all good till now.
when i console onto the officeextend 1132 AP, i get an error msg could not resolve Cisco-LWAPP-Controller.abc.uk....domain server (192.168.1.254) and Cisco-CAPWAP-Controller.home.uk...think it needs DNS set to the public ip on the local asdl box, is it ?
if this is the case, I am not sure if i can do this as this is controlled by the ISP
33 Replies 33
yep can see hits on 5246 and can see packet hitting on 12223 on perimeter firewall. i can also see these packets passing through the internal FW but cant see any return traffic from WLC ?
Did you pre stage these AP's. You might need to open udp 12222 and 12223 initially.
Scott Fella
Sent from my iPhone
-Scott
I have not added 12222 but can do
Give that a try.
Scott Fella
Sent from my iPhone
-Scott
