Cisco Point to point solution
naveed.khawar
Community Member
[1] Please specify Part Number of Cisco Access Point that has (Dual Radio), IEEE 802.11 b/g and Point to Point support available.
[2] For a distance <1 KM, Specify Part Number of YAGI Antenna which can be used with Access Point.
Thank you,
thisisshanky
Level 11
Level 11
AIR-BR1310G-A-K9-R ----- 2 (the regulatory domain could change depending on the country you are in)
AIR-ANT1949 - 2
There are more part numbers involved like,
Coax cable between antenna and bridge
dual coax rg6 cable b/n power injector and bridge
Lightning arrestor
Roof or wall mount kit
Check this thread for more part numbers
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=Getting%20Started%20with%20Wireless&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd82519
You should use the Outdoor bridge range calc utility as well as perform a formal site survey for accurate results.
http://www.cisco.com/application/vnd.ms-excel/en/us/guest/products/ps458/c1225/ccmigration_09186a00800a912a.xls
Also here is the 1300 bridge ordering guide.
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022198b.html
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
