Cisco Prime 2.1 + AIR-CT5508-K9 + AIR-AP1852I-E-K9
noc
Prime 2.1 auditing mismatch while AIR-AP1852I-E-K9 is up and running. AIR-AP1852I-E-K9 joins the controller AIR-CT5508-K9 but the prime 2.1 audit status is In Downloading State. I can not manage AP1852I from prime. What is wrong?
Thanks and Regards
6 Replies 6
 Prime only reads what  happen on WLC. Which is the AP status on WLC?
AP up time 0 d, 03 h 30 m 15 s
Operational Status REG
Admin Status Enabled
Download Status None
Try do perform  a sync between Prime and WLC.
On Prime go to Monitor>Network Devices then find and select your WLC. The sync button upside will be available to sync. Click on it, wait sometime and see AP status again.
Scott Fella
You didn't state what code you are running, but the 185x support starts at v8.1 and PI 2.1 doesn't support that code version. You need to upgrade to a version that is suppported.
Here is a matrix that you can reference and will help guide you to what controller code is supported on what version of PI.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148422
-Scott
Thanks for the solution. I have 8.3.112.0 on WLC and PI 2.1
Yeah, that is why you are seeing that mismatch:)
-Scott
