Cisco WILAN Controller Replacement
okoroji80
Level 4
Level 4
Hello Community members.,
kindly  educate me on the current happenings on Cisco wireless mobility.
I learn that Cisco is replacing the traditional  WILAN  controller  how true is this ?
For the deployment of Light-Weight AP like: AIR-AP1815i-E-k9  aside the use of controller for the integration what else can we used ?
Ric Beeching
Level 11
Level 11
Cisco have announced the end of their AireOS line of WLCs which have been going for like 15-20 years. Their successors are the IOS-XE WLCs which can also support pretty much any AP made in the past 6 years or so including the 1815i-E-K9. The compatibility matrix is good for checking these things:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#wp99531
So if you would like to order a WLC then look at the 9800 series which also has the vWLC replacement called the 9800-CL.
Cheers,
Ric
Please rate helpful / correct posts
okoroji80
Level 4
Level 4
Thank for the clarification.
How can i get a typical installation guide line for the installation using Cisco WS-C2960X-24PS-L and  AIR-AP1815i-E-K9
If you are not planning to get a controller and have limited AP's to manage go for the mobility express solution. You can find the guide below.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise-networks/mobility-express/mobility-express-getting-started.pdf
