Cisco Wireless ap 2802E-B-K9 Need help to convert to ME
EricThai21960
Good afternoon ALL
I just bought an AP 2802E-B-K9. But i dont know how to make it work. Please help me
Do i have to buy a WLC to be work with this AP?
Or convert it to stand alone AP ( ME). But i dont know how
Thank you for your help
Not a complicate process. The problem sometimes is when you need to download the required software and have no permission on cisco web page.
 First you need to console into the AP. Then, run the command show version and see if your AP is Mobility Express.
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
If so, then, you must be able to see a SSID CiscoAirProvision.
If you AP is capwap AP then you need to convert if to Mobility Express.
On this case, follow the link below:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_Cisco_Mobility_Express_Deployment_Guide/b_Cisco_Mobility_Express_Deployment_Guide_chapter_010.html
-If I helped you somehow, please, rate it as useful.-
