Cisco wireless controller 2504 authentication
ADAMA SAMB
Community Member
Hi!
In my office, we will migrate from Microsoft AD 2008 to Microsoft AD 2016 and we have Cisco wireless controller 2504.
I want to know if the cisco wireless 2504 is compatible with AD 2016.
Thanks.
Ric Beeching
Level 11
Level 11
The WLC has no concept of what version of windows you are running, as long as it supports the same authentication types as you are currently using. So, assuming you are running it like everyone else using RADIUS via NPS, then yes the 2504 is "compatible" with AD 2016.
Ric
Please rate helpful / correct posts
Ric Beeching
Level 11
Level 11
Ric
