04-11-2015 10:47 AM - edited 07-05-2021 02:54 AM
Cisco Wireless :: Is CAP1602I-E-K9 is compatible with AIR-CT2504-15-K9 controller? IF yes then How to configure 1600 series access point ?
I want to configure CAP1602 access point with controller 2504 model to enable wifi access with secure Impact ..
Is this access point accept capwap ap commands or let me know what commands are for config ?
Rgds,
Parag
04-11-2015 02:12 PM
Yes, it is compatible. Make sure AP came with lightweight image & your 2504 is having software code anything above 7.4.100.0
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
If this AP is WLC managed, you do not require to do any config on AP, all config doing via WLC.
Have you configured your 2504 properly ? If so you simply want to put your AP on same vlan as 2504 management vlan, then AP will find WLC via L3 broadcast & it will register to WLC.
Here is the 2504 Deployment guide that should helps you
Rasika
**** Pls rate all useful responses ****
04-11-2015 10:21 PM
Hello Manannalage Rasika,
First of all Thanks for your reply.
Actually We have CAP2602E-N-K9 and CAP1602I-N-K9 access points from that :
CAP2602E-N-K9 AP already configured with WLC AIR-CT2504-15-K9 and working fine as a Secure Impact using following commands:-
#capwap ap ip add _ _
#capwap ap controller _ _
#capwap default gateway_ _
Now I want to connect CAP1602I-N-K9 AP with same WLC.
I will check first version of WLC. If suppose its not above 7.0 version then what how will have to upgrade so that current working AP will not effect after upgradation.
Regds,
Parag
04-12-2015 12:53 PM
Here is the WLC software upgrade procedure.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68835-wlc-upgrade.html
Here is 7.6.130.0 release notes, if you wish to upgrade for that code
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn76mr03.html
Yes, this will not affect the current working AP as newer software code will support 2600 series as well.
Rasika
