Cisco WLC 2504 Web Auth Auto Launch Browser
Bmodlin
I have configured a Guest SSID using Web Auth.  I have installed a 3rd party SSL certificate and it is working perfectly.  Once connected to the SSID if they launch a browser it redirects them to the login page.
The issue is they want the browser to automatically launch once successfully connected to the guest SSID.
Is this possible?
10 Replies 10
 Try to add the URL they want on the "Redirect URL after login" under SECURITY tab, web login page.
-If I helped you somehow, please, rate it as useful.-
Unfortunately, that did not work.
Sandeep Choudhary
if not then configure config network web-auth captive-bypass disable on WLC.
question:
are you using default webauth page from cisco wlc or using ISE ?
Dont forget to rate helpful posts
I am using the default web auth page.
What exactly will "config network web-auth captive-bypass disable " do?
Here is the output of the Show network summary
Web Auth Captive-Bypass .................. Disable
It is already disabled.
I would make sure that the device has been deauth’d prior to do testing. Also if you are using sleeping client, you need to remove the device Mac from that list.  The login should only appear when the client is new to the controller.  That means not in the RUN state. Sleeping client can keep clients active for up to 30 days.
-Scott
How do you De-Auth?
config client deauth
-Scott
does that deauth all clients?
one more question.... Will this work for all OSs and browsers?  Windows 7, Internet Explorer, Chrome, etc.?  Or is it specific to certain browsers and OSs?
