Bookmark
Subscribe
2169
cisco wlc 9800 HA configuration issue
Manish Manwal
we configured a SSO HA in cisco wlc 9800-l. we configured active wlc1 with RPI+RP and then factory reset wlc 2.
once wlc2 rebooted, we configured basic configuration like mgmt ip wireless wlan, user and EtherChannel to uplink and configure RMI+RP in wlc2. it would be rebooted automatically but nothing happened, and we lost the connection of wlc2. even we are not able to take access via consol cable. any idea what could be the issue??
THANKS
MANISH MANWAL
10 Replies 10
Loss access to wlc2 is first sign of success sso.
From wlc1 monitor did you check the health of both wlc's?
MHM
from wlc1, no standby device is showing
THANKS
MANISH MANWAL
marce1000
 - To use the console on the standby wireless controller, execute
      the following commands from the active Catalyst 9800 Wireless controller
             conf t
             redundancy
             main-cpu
             standby console enable
 M.
already configured that but not working.
i have asked onsite person to reboot wlc2 manually. lets see. may be wlc2 has hung.
THANKS
MANISH MANWAL
can I see the WLC config page for SSO
in both WLC
MHM
see attached png
THANKS
MANISH MANWAL
Can you access to wlc
Wlc#Show redundacy
Wlc#show chassis rmi
Wlc#test wireless redundacy rping
Can yoh share this
MHM
ok
THANKS
MANISH MANWAL
 - Use these commands to further check HA SSO (states) :
show redundancy | i ptime|Location|Current Software state|Switchovers
show chassis
show chassis detail
show chassis ha-status local
show chassis ha-status active
show chassis ha-status standby
show chassis rmi
show redundancy
show redundancy history
show redundancy switchover history
show tech wireless redundancy
show redundancy states
show logging process stack_mgr internal to-file bootflash:
 M.
                     >...i have asked onsite person to reboot wlc2 manually. lets see. may be wlc2 has hung.
 - Also note that if wlc2 would be factory reset again and there is still no  console , then of course the fundamental problem with the box need to be resolved first (to get an initial configuration going) .  After that use this  guide :
                      https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/9800/17-1/deployment-guide/c9800-ha-sso-deployment-guide-rel-17-1.pdf
            When all of that is finished checkout the configuration from the HA-primary  controller with the CLI command
                         show tech wireless and let that be analyzed with Wireless Config Analyzer
 M.
