Cisco WLC and Cloudflare
NelsonGuedes
Anyone have problems with WLC captive portal, after 1.1.1.1 Cloudflare dns have been launch?
I have 1.1.1.1 as my virtual web portal, and after the relase from cloudflare 1.1.1.1 dns, my captive portal stop to redirect after accept disclaimer.
Anyone have a similar problem?
Scott Fella
Nelson,
I think many others have moved away from using 1.1.1.1 a while ago to be honest. If your DNS is internal then it should be fine. I’m also assuming that you have installed a certificate to resolve the dns name to 1.1.1.1?
-Scott
Hello @Scott Fella,
This is for guest only, so the DNS is public.
Regarding the certificate, yes I have it for 1.1.1.1
Tonight i will change the address 1.1.1.1, to see if it solve the problem.
This just happen today, which is strange, since CloudFlare launch yesterday the new 1.1.1.1 public dns.
When I have used a public DNS, I typically will use on of the public ip for the virtual and then have an a-record with the hostname to resolve to the public/VIP ip. That should work for you. You will need to reboot the controller for the VIP to take as it will prompt you for that.
-Scott
Ok. I will try that. However i need to generate on WLC a new certificate for that VIP right?
I will do it tonight and i will reply tomorrow with na update.
