Cisco WLC : AP automatic configuration for flexconnect parameters and ap group
stephane.walker
Community Member
Hello !
Is there a way to configure cisco WLC to automatically set flexconnect parameters such as Vlan support and Native Vlan ID when an access point join the controller ?
Same question to assign the access point to a specific AP Group ?
PS: The access points are set with usine parameters and the WLC is in version 7.4
Thank you for your answers !
Stephane
bret
Level 5
Level 5
To my knowledge these features are not available in 7.4, but from what I understand 8.0 will have similar features. I can say that 7.6 has global commands, not sure if its part of 7.4.
If it is you can navigate there Wireless>Access Points>Global Configuration you can do things like configure your primary and backup controllers, set login credentials, pre-download images to AP's.
Please rate if you find the information helpful.
