Cisco WLC with XenMobile MDM
Maurice Ball
Level 3
Level 3
Is it possible to use XenMobile MDM to do wireless certificate base authentication for Cisco WLC clients without the use of ISE?
Scott Fella
Maurice,
If you have AD and your a Microsoft shop, here are some examples of using Microsoft NPS;
https://supportforums.cisco.com/docs/DOC-32752
http://networklessons.com/wireless/peap-and-eap-tls-on-server-2008-and-cisco-wlc/
-Scott
5 Replies 5
Scott Fella
Certificate based authentication, 802.1x, requires a radius server. MDM will not work as a radius server unless XenMobile has done something new. You don't need ISE, but you can use any radius server from Microsoft, Cisco or even FreeRadius.
-Scott
Thanks, do you know where I can find a example or information on how this is setup?
Scott Fella
Maurice,
-Scott
Great information thanks
No problem
-Scott
