client not able to connect to 9800 wlc-wireless
Anjana A
Hello Team,
we are using new 9800 wlc in our infra
WLC-9800/ios-17.9.4a
AP-Mode:Flex-connect
AAA server-ise
All of sudden all clients from one particular not able to connect to wireless -corporate ssid.
Clients struck in 802.1x state and error is
2024/03/27 03:20:25.621904275 {wncd_x_R0-0}{1}: [client-keymgmt] [17614]: (ERR): MAC: xxxxxxxxxxx  Keymgmt: Failed to validate eapol mic. MIC mismatch.
2024/03/27 03:20:25.621909925 {wncd_x_R0-0}{1}: [client-keymgmt] [17614]: (ERR): MAC: xxxxxxxxx
  Keymgmt: Failed to validate eapol key m2. 11r MIC validation failed
2. Reason: CO_CLIENT_DELETE_REASON_KEY_MGMT_MIC_VALIDATION, details: , fsm-state transition
Please confirm what needs to be checked on device end?
Anjana
7 Replies 7
we are running 3.2 ise version and bug is 3.1 version
 - Also https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs38655 , if not applicable and or following an earlier bug report mentioned , then you need to report back to TAC
 M.
Sorry I make you waiting
Can you check PSK ypu use in both wlc and wifi host' this log can indicate mismatch key
MHM
No Issues MHM..
Actually we have upgrade the ios to 17.9.5 which resolved the issue.
Anjana
Thanks alot for update me
Have a nice day
MHM
mgalvez2022
Is there a work around to this? I have this issue with a flex connect site as well, and I cannot update this controller yet, and It will take a while to get an approval to upgrade.
