Clients can't connect to AP in flexconnect group
bravotom99
we are converting a large number of AP's from autonomous to lightweight and will be using flexconnect groups on a 7510.  The flexconnect groups also have flexconnect ACL's which we are using for redirecting NAC & posture traffic.  We have tried pre-staging the AP mac's into the flexconnect groups using the command "config flexconnect group_name ap add ap_mac".  We then convert the AP to unified mode and it joins the WLC.  That all appears to work fine.  We see the AP on the WLC and in the flexconnect group.  It says Joined in the flexconnect group.
The issue we have is that clients cannot connect.  The client status will say 'POSTURE_REQD'.   The only solution we found was to remove the AP from the flexconnect group and then re-add it back.  After that, it works fine.  Anyone have any suggestions or insight?
0 Replies 0
