CMNO
eperezb
Level 3
Level 3
I currently have CMNO, I would like to continue with the Meraki technology, which courses or certifications do you recommend taking
Hello @eperezb CMNO (Certified Meraki Network Operator) evolved into ECMS1 (Engineering Cisco Meraki Solutions 1) and your CMNO is the equivalent of that. The next step would be ECMS2. There is an interest form to fill out here https://community.meraki.com/t5/ECMS2/ct-p/ecms2 and you need to be recommended by your Cisco Meraki team so they can assist with getting you enrolled in ECMS2. After the completion of CMNO/ECMS1 and ECMS2, there will be a certification exam, passing that awards the CMSS, Certified Meraki Solutions Specialist. I believe the certification exam is still in the works, so stay tuned for that. Keep checking back on the Meraki Learning Hub page @jdsilva mentioned for updates. Hope that helps and good luck.
5 Replies 5
thanks for the information
thanks
Hi @eperezb!
Cisco Meraki Solutions Specialist certification is finally here! Read our blog post to learn more and register for the exam today!
Meredith W | Community Manager, Cisco Meraki
Found this helpful? Give me some Kudos! (click on the little up-arrow below) New to the community? Get started here
