Compatibility between Cisco AP & products
limjewyen
Hello all,
I would like to check if Cisco AP is compatible with Motorola WT4000 Series and Zebra QL Plus Series Printers.
Cheers
Elliott Shawd
Yes. I didn't look too closely at each model of these devices, but make sure "WiFi" is included in the specs. It seemed all of the Symbol PDA devices were WiFi compatible, but I'm not sure about the printers. It seemed the 420 Plus printer included wifi.
