CONFIGURING 2720I WIRELESS ACCESSPOINT
isaaco001
Level 3
Level 3
Dear Community,
I am trying to configure a 2720i Acess point.when i configured 1130AG.I configured the e0 interface and was able to reached the browser gui for the rest of the configuration.Does tehe 2720i have a browser for configuration?In the attached file,you will see that i have configured the g0 interface.The problem is i cant ping that interface at all.I have done a show flash: and boot up process to show important details that i might be missing.
To add,the ap come in lwapp mode and i found the k9w7 in flash so i changed it to standalone through
Boot:flash/standalone image
Thank you all!
Sandeep Choudhary
how you configured the switch port where it is connected ?
Also configure the default-gateway on AP.
Dont forget to rate helpful posts
6 Replies 6
Sandeep Choudhary
Hi Sandeep,
Thanks for you answer. I have configured the default-gateway  now as you can see in the show run in the file attached.192.168.1.1 is the default gateway. What should be configured on the switch?I am still troubleshooting.
Isaac
you must allow the VLAN(X) on switch port.
Hi Sandeep,
test
test
isaaco001
Level 3
Level 3
Sandeep,
It finally worked!I just configured the bvi interface with and ip and removed the ip on g0.I have to use a complete new set of patch cords,because i thought i could be layer 1 issue.I can now access the gui.
Attached is the attached configs for sho run(working).
Thanks for amazing support.
