connecting two bridges is there a tool to align antennas
dedube23
Hello all this is my first bridge connection. Please is there any tools like with the acu that can help with antena alignmet
David
derwin
Level 5
Level 5
David,
If you look under the diagnostic menu on the NON root bridge you will see that there is an antenna alignment test.
Run this test then adjust your anttenna and re run the test until you have the best signal strength and quality that you can get
