Connecting WLC dierectly to Firewall
Anvar Mohammed
i have one 2112 Controller connected deirectly to a firewall, there is no other network infrastructure avialable, so the APs are also dierctly connected to back pannel of Controller.
can i have multiple WLANs in this scenario ? Will firewalls can support trunk interface ?
did any body had this kind of scenario before, was it running properly ?
thanks,
Anvar
Scott Fella
It's not recommended to connect the AP's to the back of the WLC. It is recommended to connect the AP's to a switch. As far as the FW doing trunking, depends on your FW.
Sent from my iPhone
-Scott
