The elevator shaft or a ventilation shaft would be very direct routes, but the reflections and RF interference may keep you from getting a reliable link.
8 floors is only 80 feet, so it may be best to put one antenna on the roof pointed straight down at an antenna inside or outside of a window on the ground floor.
Matthew Wheeler
Chief Wireless Architect
www.BlueModal.com
