Hi all,
While working on a site, I found the following problem.
I need to convert an AP model CAP2620I-E-K9 from lightweight to autonomous.
It is using the following IOS/firmware stored in flash: "flash/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"
A show ip int brief reveals only the following interfaces:
BVI1
GigabitEthernet0
GigabitEthernet0.1
No wireless interfaces at all.
I presume that a new firmware will be needed to make it work as autonomous.
My questions are:
1) Which firmware do I need?
2) Can it be downloaded from Cisco?
3) Should I use ftp to upload the firmware to the AP?
Thank you in advance for your help.
Best Regards,
Davide Ferreira
