ā08-23-2016 10:10 AM - edited ā07-05-2021 05:42 AM
I have AIR-AP2702E-UXK9 access points and I am unable to provision it here in Kuwait as there is no regulatory domains available for this AP in Kuwait. I opened a case with TAC and its taking too long for them to fix the issue and they haven't given any ETA. Is there any way that I can change the firmware to convert it to normal access points? If yes, how do I achieve that?. I have downloaded the ap3g2-k9w8-tar.153-3.JD firmware.
Ajin.
Solved! Go to Solution.
ā08-23-2016 12:04 PM
I do not think there is another way. Either replace the AP with another that has a regulatory domain configured at manufacturing or work with TAC
Rasika
Rasika
ā08-23-2016 08:31 PM
Thanks Rasika...So you're saying there is no option to change the firmware of the AP to a specific regulatory domain AP?
ā08-23-2016 11:10 PM
Yes, that's right.
Rasika
ā08-24-2016 02:15 AM
Thank you...So I'll have to wait for Cisco to fix the issue soon and the customer is very unhappy with the delay in the implementation...
ā08-24-2016 03:31 AM
Hi Rasika,
Does the AP firmware has got anything to do with the regulatory domain? Suppose somehow if I change the AP firmware, will it still be universal or provisioned?
Ajin.
