Couple WCS issues
oded
Community Member
1.    Help!!! is there a presentation to explain the abilities and advantages of the WCS that can be post here?
2.    How big are the AutoCAD files that can be imported to the WCS? is it recommended to use AutoCAD files?
Oded
George Stefanick
Here is a link to WCS links and a video. As for CAD files, i dont think that is a supported format, but dont quote me on that. I know you can do jpg gif etc ...
http://www.cisco.com/en/US/customer/products/ps6305/index.html
