Creating Dual SSID's
dtmyers
We are running phat architecture (WLSE, ACS, 1230 AP's) and PEAProtocol. I want to create additional SSID's on every AP (WPA-PSK) for vendors.
My questions is this: "Are there any good documents that discuss the creation of dual SSID's, VLAN/AP configuration, and/or best practice approaches?"
frankzehrer
Level 4
Level 4
Hi Darin,
jep there are some documents.
Using VLANs with Cisco Aironet Wireless Equipment
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801d0815.shtml
For usage of a WLSE, PEAP and ACS have a look here
Protected EAP (PEAP) Application Note
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_technical_reference_chapter09186a008025d6ee.html
Additional Information about WDS can be found here
Wireless Domain Services Configuration
http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801c951f.shtml
These documents will give you the right hints for your task.
Best reagrds,
Frank
dtmyers
Thanks Frank!
