in my environment i've a virtual wireless lan controller version 7.5.102 running on VMWare infrascture.
All APs are configured in Flex Connect mode, grouped in 2 differnt groups to broadcast a total of 3 WLAN.
I'd like to setup a new guest wlan from where clients connected aren't able to reah some server on the same LAN.
I suppose that with ACLs i can do what i need but i can understand how set-up correctly a guest WLAN due to the documentation refers to creation of a new interface but the virtual controller it seems to be different from the phisical controllers in interfaces management.
There's a simple way to create a new WLAN and apply an ACL to it? It seems that ACLs are applicable to controller's interface or Flex Connect group, but i need to applicate only to a single WLAN.
Thanks in advance
Erik
