Critical System Event on WLC
muhammad-noman
Hai,
We have installed Cisco WLC 5508, from the last few days we have been observing Critical System Event being continuously fired on Cisco WLC. The error is as under
*spamApTask4: Jun 26 10:39:42.438: %OSAPI-5-OSAPI_INVALID_TIMER: Failed to retrive timer.
Can any one please help us out in finding the cause of that error and any suggestions how we may mitigate that error.
Muhammad Noman
2 Accepted Solutions
Sandeep Choudhary
Which version of software u r runing on wlc:
Paste the output of the command from wlc: sh sysinfo
There is bug in specific software such as 7.0.110.29, 7.0.98.0 - CSCth71298
Dont forget to rate ehlpful posts
Its a bug sure:
CSCth71298
*spamApTask4: %OSAPI-5-OSAPI_INVALID_TIMER: timerlib.c:543 Failed to return.
Check the release notes of 7.0.116.0
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn7_0_116_0.html
Update the wlc to 7.4.121.0 version.
Dont forget to rate helpful posts
Sandeep Choudhary
Dear Sandeed,
The software version on WLC is 7.0.116.0
Its a bug sure:
CSCth71298
