CSCwi78109 | issue with WLC running 17.9.5 ? | feature or system busy
M.Voortmans
CLI agent: Error while processing NVGEN command: ...
There is an impact to the management GUI + we don't know if running configuration is saved, due to the face each save action results in "CLI agent: Error while processing NVGEN command" warnings. How sure are we, that our configuration is intact and correct saved!?
When saving configurations, we see following messages:
% Command 'location algorithm' unsuccessful: feature or system busy
% Command 'location expiry' unsuccessful: feature or system busy
% Command 'location notify-threshold' unsuccessful: feature or system busy
Also messages in GUI:
example:
Jul 2 12:26:52.996: %CLI_AGENT-1-NVGEN_ERR: Error while processing NVGEN command: cloud-services
Jul 2 12:26:52.997: %CLI_AGENT-1-NVGEN_TRACEBACK: Traceback: 1#b30f30cb912860428c70b1e72fb10927 ....
6 Replies 6
Mark Elsen
  - You could try to reboot the controller and check if the problem goes away ; (if production permits)
     As far as verifying a saved configuration , a trick could be by showing the running config through putty with logging enabled ,
     then save it and copy the configuration from flash to an external repository and compare both ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Leo Laohoo
This error message occurs when the WLC is not adhering to the "80% rule" and is overloaded with AP.
C9800 design is no different and, generally, Cisco recommends limiting the load to around 80% of the AP and client scale.
The 80% scale is just a recommendation to start planning the design and deployment of a catalyst wireless network as this is tested and validated number.
For C9800-80, for example, this means 4800 APs and/or around 50k clients. Does this mean that you cannot have six thousand APs on a single C9800-80? No, not really; Cisco has a lot of successful deployments at maximum scale. The 80% scale is just a recommendation to start planning the design and deployment of a catalyst wireless network.
I've had this error message (and subsequent Tracebacks) when our 9800-80 had over 5400 APs.  This same error message has also appeared on our 9800-L with 210 APs.  Uptime for either WLC is >45 days and we've seen this in 17.9.4, 17.9.5 & 17.12.3.
Do not load the 9800-80 more than 50% or risk a memory leak like below:
9800-80, 17.12.3, 3050 x APs, Uptime:  6 weeks9800-80, 17.12.3, 3050 x APs, Uptime: 6 weeks
Our WLC is not overloaded with AP; We have just 2 WLC’s in HA-State (SSO) and just a limit of AP’s: 15 AP’s, running 17.9.5 : Uptime 6 Weeks, 21 Days.
[cid:image001.png@01DACD24.223EAAE0]
In our situation, it looks like it was started when Smart Licensing was enabled (cloud access).
Lot of alert notifications when opening GUI Dashboard:
[cid:image008.png@01DACD25.85883070]
Is this a 9800-L?
Post the complete output to the following commands:
sh platform resource
sh platform software status con brief
Hi Leo,
See output, below.
wgtsnlve01#sh platform resource
**State Acronym: H - Healthy, W - Warning, C - Critical
Resource                 Usage                 Max             Warning         Critical        State
RP0 (ok, active)        H
Control Processor       11.91%                100%            80%             90%             H
  DRAM                   4729MB(30%)           15467MB         88%             93%             H
ESP0(ok, active)        H
QFP        H
  DRAM                   174021KB(9%)          1835008KB       85%             95%             H
  IRAM                   207KB(10%)            2048KB          85%             95%             H
  CPU Utilization        0.00%                 100%            90%             95%             H
wgtsnlve01# sh platform software status con brief
Load Average
Slot  Status  1-Min  5-Min 15-Min
1-RP0 Healthy   1.14   1.18   1.23
2-RP0 Healthy   1.16   1.15   1.16
Memory (kB)
Slot  Status    Total     Used (Pct)     Free (Pct) Committed (Pct)
1-RP0 Healthy 15838740  4843796 (31%) 10994944 (69%)   4922096 (31%)
2-RP0 Healthy 15838740  4500504 (28%) 11338236 (72%)   4790256 (30%)
CPU Utilization
Slot  CPU   User System   Nice   Idle    IRQ   SIRQ IOwait
1-RP0    0   2.40   0.80   0.00  96.79   0.00   0.00   0.00
         1   4.00   1.40   0.00  94.58   0.00   0.00   0.00
         2   2.59   0.79   0.00  96.60   0.00   0.00   0.00
         3   0.70   0.80   0.00  98.50   0.00   0.00   0.00
         4   0.60   0.70   0.00  98.70   0.00   0.00   0.00
         5   3.30   0.80   0.00  95.90   0.00   0.00   0.00
         6   0.50   0.60   0.00  98.90   0.00   0.00   0.00
         7  99.80   0.09   0.09   0.00   0.00   0.00   0.00
         8   0.00   0.00   0.00 100.00   0.00   0.00   0.00
         9   0.10   0.00   0.00  99.89   0.00   0.00   0.00
        10   0.19   0.09   0.00  99.70   0.00   0.00   0.00
2-RP0    0   2.20   3.70   0.00  94.10   0.00   0.00   0.00
         1   2.50   3.50   0.00  93.90   0.00   0.10   0.00
         2   2.30   3.60   0.00  94.10   0.00   0.00   0.00
         3   0.50   0.70   0.00  98.79   0.00   0.00   0.00
         4   0.30   0.50   0.00  99.20   0.00   0.00   0.00
         5   3.20   0.70   0.00  96.10   0.00   0.00   0.00
         6   0.60   0.60   0.00  98.80   0.00   0.00   0.00
         7  99.80   0.20   0.00   0.00   0.00   0.00   0.00
         8   0.10   0.00   0.00  99.90   0.00   0.00   0.00
         9   0.10   0.10   0.00  99.80   0.00   0.00   0.00
        10   0.00   0.00   0.00 100.00   0.00   0.00   0.00
On this site location, we have very small HA-deployment with 2x C9800-L-C-K9 and 15 AP’s (types: CW9164I-E) .
Best regards,
Marc
