DHCP issue with Wirless 1811W Router
mahesh18
Level 6
Level 6
Hi Everyone,
I am setting up 1811w router for accessing internet.
DHCP is configured on it but it is not providing IP to laptop connected on port fa6.
Here is config of router
dot11 ssid internet
vlan 98
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 0 010907150A59111C390C
ip source-route
ip dhcp pool WIRELESS
   import all
   network 192.168.98.0 255.255.255.0
   default-router 192.168.98.1
   dns-server 4.2.2.2
   lease 3
ip cef
no ipv6 cef
vtp mode transparent
archive
log config
  hidekeys
vlan 98
bridge irb
interface Dot11Radio0
no ip address
encryption vlan 98 mode ciphers tkip
ssid internet
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
no cdp enable
interface Dot11Radio0.1
interface Dot11Radio0.98
encapsulation dot1Q 98
no cdp enable
bridge-group 98
bridge-group 98 subscriber-loop-control
bridge-group 98 spanning-disabled
bridge-group 98 block-unknown-source
no bridge-group 98 source-learning
no bridge-group 98 unicast-flooding
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface FastEthernet0
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
switchport access vlan 98
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
shutdown
interface Vlan98
no ip address
interface Async1
no ip address
encapsulation slip
interface BVI98
ip address 192.168.98.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
bridge 98 protocol ieee
bridge 98 route ip
line con 0
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
end
thanks
mahesh
Stephen Rodriguez
You new to add bridge-group 98 under the VLAN 98 interface.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hi Steve,
Thanks for reply.
I did that but then int vlan 98 went up down.
also still laptop not getting dhcp.
thanks
mahesh
hi steve,
One thing to add is that without int vlan 98
bridge-group 98 command wi fi laptops are able to get the IP from dhcp but wired pc does not.
thanks
mahesh
