DHCP with Cisco ap 1300
nkila_lna
hi friends,
i want to use two dhcp pool with Cisco ap 1300 and each pool ip is associated with an ssid and a vlan.
is'it possible to do this configuration with Cisco ap 1300 ???
urgent
thanks
andrew.brazier
Level 4
Level 4
Short answer: yes! Make sure your switches support VLANs and have the correct VLANs configured and set the AP switchport to be a trunk port.
nkila_lna
hi friend,
i do what you say but if i try to connect to vlan 2, my wireless card can't get ip address from dhcp pool v2.
plz see my config bellow:
ip subnet-zero
ip dhcp pool v1
network 1.0.0.0 255.0.0.0
default-router 1.0.0.254
ip dhcp pool v2
network 2.0.0.0 255.0.0.0
default-router 2.0.0.254
dot11 ssid ssid-vlan1
vlan 1
authentication open
dot11 ssid ssid-vlan2
vlan 2
authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root access-point
l2-filter bridge-group-acl
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 input-address-list 700
bridge-group 2 output-address-list 700
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 1.0.0.100 255.0.0.0
no ip route-cache
interface BVI2
ip address 2.0.0.100 255.0.0.0
no ip route-cache
control-plane
bridge 1 route ip
end
regards,
