dial backup for Cisco building-to-building Connection
fluoro
how is possible to create an automatic dial-backup for wireless bridge link?
If yes, how can do it? can i have an example?
kmarrero
Level 4
Level 4
The following links should help you set up the dial back up. You will probably have to use the Dialer Watch with the wirless set up.
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a0080094cb0.shtml
http://www.cisco.com/en/US/tech/tk801/tk133/technologies_configuration_example09186a008009455e.shtml
