Difference between ise in c9800
Leftz
Level 9
Level 9
Hi, In C9800 wlc system, we can see radius configuration with ise, but in other cases, we can see they use tacacs instead of radius. In 9800 system, what is difference between radius and tacacs? Thanks
14 Replies 14
Mark Elsen
 - FYI : https://www.google.com/search?q=what+is+the+difference+between+radius+and+tacacs&rlz=1C1CHZL_enBE751BE751&oq=what+is++the+difference+between+radius+and+tacacs&aqs=chrome..69i57j0i512j0i22i30l5j69i64.6831j0j7&sourceid=chrome&ie=UTF-8
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Scott Fella
I think you need to understand why you might use TACACS for vs Radius, which is typically used these for user access.  Back in the day's radius was used for network device access until TACACS was born.  There are still networks out there that use radius for network device access, because they don't have a AAA server that supports TACACS.  Hope that somewhat clarifies your question.
-Scott
Rich R
Cisco devices normally use TACACS to authenticate and authorise user access to the device itself - device management.
TACACS is a Cisco proprietary protocol (so mostly only used by Cisco devices) but Cisco did release the code for it so a few other vendors have released server and client support for it in a limited way.
Radius is a standard used right across networking.  It can be used for management access (like TACACS) but on Cisco devices it is mostly used for user access authentication and management eg. WiFi users, remote access users etc.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Leftz
Level 9
Level 9
Thanks for your reply!
Now the c9800 wlc is using Radius. If we change it to TACACS, what do we need to do? just setup TACACS and remove Radius?
Not necessarily - it depends what it's using the radius for.  For example if you're using it to authenticate an 802.1x WLAN you can't remove it.  But if you're using it to authenticate management users then yes you could replace it with TACACS.  You'll also have to make sure the ISE server is correctly configured.  When you're sure TACACS is working then you could remove the radius.
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/214490-configure-radius-and-tacacs-for-gui-and.html
Scott Fella
Please make sure you understand the configuration before you change anything.  You just need to review ISE and TACACS configuration documentation so you can follow how your setup is and what it is doing.  Then understand how ISE radius is used to authenticate clients.  Then and only then you will be able to understand the current policies defined.
-Scott
Leftz
Level 9
Level 9
@Rich R and @Scott Fella  Thanks for your comments. The below document is talking about radius/tacacs and wlc configuration. Based on the document, the two server radius and tacacs need to be configured at ISE. There are some same features that the two servers own. My question is when WLC need the same feature, which server(Radius or tacacs) would provide the function?
TACACS is generally the first choice for management user authentication on Cisco devices.
RADIUS is the standard for client access authentication across networks generally.
And when I say authentication I actually mean AAA - authentication, authorisation and accounting.
Leftz
Level 9
Level 9
I am not asking the difference of the two server at this moment. Instead, I would like to know when both servers Radius/TACACS are installed and configured at same ISE/WLC, if a device request the same service feature that the two servers own, which server will respond to it? Is there a mechanism to handle the issue? Or only one of the two server can be selected?
Well you can configure primary and fallback options with aaa config so it might be possible but I really would not recommend ever doing that.  But if you did that then they'd be selected in the order you configure them to be used.
Leftz
Level 9
Level 9
Thank you very much for your reply. It make sense.
"Not necessarily - it depends what it's using the radius for.  For example if you're using it to authenticate an 802.1x WLAN you can't remove it.  But if you're using it to authenticate management users then yes you could replace it with TACACS ..."
Our system uses 802.1x radius for users, so we cannot remove radiius.
"Well you can configure primary and fallback options with aaa config so it might be possible but I really would not recommend ever doing that.  But if you did that then they'd be selected in the order you configure them to be used.  "
Regarding the order we selected, I think you mean AireOS, but looks like we do not have the function at catalyst 9800. so when both Radisu and tacacs co-exist in c9800, there should be a mechanism to control/decide which one(Radius or tacacs) to take care of users authentication and authorization
Please refer back to the answers already provided.
Leftz
Level 9
Level 9
I changed the previous post after i reviewed the question
Regarding the order we selected, I think you mean AireOS, but looks like we do not have the function at catalyst 9800. so when both Radisu and tacacs co-exist in c9800, there should be a mechanism to control/decide which one(Radius or tacacs) to take care of users authentication and authorization.
IOS aaa config allows to specify multiple groups so you should be able to use both in order of preference. eg:
aaa authentication login default group mytacacs group myradius local
