Disable all workstation-to-workstation communication on wireless network
Gents,
Is it possible to disable workstation-to-workstation communication in a wireless network using Cisco ISE ?.
I know it can be done in the wired network using dynamic ACLs.
Edouard.
Scott Fella
On the controller there is a feature to disable peer to peer.
-Scott
I have a 2500 WLC and we are about to procure a 9800 WLC.
Let me find that feature to disable peer-to-peer on the Wireless controller.
