Disable ssid broadcast from CLI
Scott Fella
How do you disable bradcast SSID on a 1200 from the CLI. Tried searching but couldn't find anything. I know you can do it from the GUI. Thanks
-Scott
int dot0
ssid xxxx
no guest-mode
regards bernhard
int dot0
ssid xxxx
no guest-mode
regards bernhard
Thanks!
-Scott
