Electromagnetic Interference (EMI) in wireless?
darojim
Frequent Visitor
Frequent Visitor
What considerations Do I have to know? or Are there any known problems to implement wireless in a Power substation (Electrical) with EMI and Noise?
scottmac
Level 11
Level 11
You're probably OK, but only a good site survey will give you the solid information you need before committing to the setup.
Good Luck
Scott
xavier.zhindon
Community Member
HI.
AS AN ADVICE FOR YOU, PERHAPS THE BEST WAY TO AVOID EMI AND NOISE IS BY REDUCING THE SENSITIVITY OF THE RADIO AND ENFORCING THE USE OF SHIELDED ANTENNAS (SECTORIAL).
