Enhanced Open Support on Cisco 5508 Wireless Controller and 3702i AP's?
Jim Matuska
Is there any support for Enhanced Open Security on 5508 Wireless LAN Controllers and 3702i Wireless Access Points?  I'm running the latest supported software on the WLC's and AP's (Version 8.5.171.0) but it doesn't seem to show Enhanced Open Security on the Layer2 security configuration.  Is this supported or do I need to upgrade to newer model AP's and Controllers?
Scott Fella
You need a controller to run v8.10 or the 9800’s. You always can reference the release notes and search for enhanced open. If not there, it’s not supported is the basic rule of thumb. You should look at upgrading both the controller and access points. My suggestion is to move to the 9800 controllers and the 9100 access points.
-Scott
