error leap authenticate....too many sessions?
markanthony
Level 3
Level 3
I am running WLSE 2.12 express. I have my 7920 IP phones registering via leap all using the same username and password on the phones. Encryption keys are set to regenerate every 3 minutes.
If I login to my WLSE box and go under ADMIN -> AAA AUthentication -> Sessions I can see thousands of sessions in there. If I release them all then the phones start authenticating again.
Anyone see that or have any ideas?
Thx
r-simpson
Level 9
Level 9
Did you try restarting the WLSE. Sometimes a restart clears all the sessions and resolves the problem. Try this and check if it works.
iziks
Level 2
Level 2
I have same issue.
Did you find the problem???????????
Yes, I opened a TAC case with Cisco and they have confirmed that this is a bug. Looks like it will be fixed in the next release mid february. v2.13 will fix the issue.
bug:CSCsb44467
