Failing to Access Web Interface of 2602i AP
Straight from the box I have connected the 2602i wireless access point to the cable LAN and I can ping its default IP 192.168.1.1. When I try to access the AP using web-browser it fails I guess because web access is disabled by default. I'm unfamiliar with the commands on the system.
Can somebody help with the commands.
Thanks in advance
31 Replies 31
Hi, i have similar problem. i have aironet 2602I-e-k9. I cannot pick it up on web interface, when i try to configure via CLI the command "configure terminal" is rejected. how do i configure it???
m.rana.ku
In the following video step by step process has been shown How to Configure Cisco AIRONET 3602i Autonomous/Standalone Access Point using GUI with WPAv2 Authentication Key.
https://www.youtube.com/channel/UCmZZ2BNGXQH1HPS3uIVnr7A?sub_confirmation=1
https://youtu.be/AwuWsGGofT4
Configuring Aironet Access Point with WPAv2 Authentication in GUI :
1. In Easy Setup
Under Network Configuration
Edit AP hostname, Static IP, Subnet mask and Default Gateway
Under In Radio Configuration
Create SSID name WLAN_New under Radio 2.4GHz and select Broadcast SSID in Beacon
2. Apply Encryption Modes to AES CCMP
3. Enable WPAv2 and apply WPA Pre-shared Key: to SSID
4. Enable Wireless Radio Interface (Radio0-802.11N2.4GHz/ Radio1-802.11N5GHz) UP
5. Save the configuration
6. Finally check the SSID Wi-Fi connection, Security Key, IP address and browsing through internet
