First wireless Project
maxwell-taylor
Community Member
Other than the standard CISCO AP , NIC and RADIUS server,is there any recommended product (hware or sware) I should be looking at before attempting to put a basic wireless LAN together...First time attempt
jhelm
Community Member
One aspect you may consider that is not hardware nor software however equally as important as the correct choices each is having a proper site survey and installation done to design the network based on your needs. If you are simply trying to test wireless in a small area for curiosity sake then this is not needed however if you are going to implement this in a large environment then it is an absolute requirement for proper functionality. For more information go to www.netcomitl.com
