First Wireless setup
blackrose
Community Member
I am setting up a wireless solution and am in need of a bit of help. I have 2 1300s and a 1200. The building is shaped just like a backwards F. I have 1 1300 connected to the gateway then I have a 1200 acting as a repeater, and then the last 1300 picking up the signal from the 1200? The only access point I can connect to is the wired 1300. The other 2 devices are not wired. Can anyone point me in the direction as to what the devices need to be configured as? What I have now is the wired 1300 is root, the 1200 is repeater and the last 1300 is non-root. All have the same ssid. Anyways I can see all 3 devices and the 2 1300 both have the same ssid, the 1200 has no ssid broadcasting. Thanks a ton for any help.
blackrose
Community Member
Ok so I can now connect to the 1200 repeater and the "wired" 1300, but I cannot get to the 2nd 1300. Do
I need to set it as a repeater to?
Aironet product only supports repeater for AP, not bridges. BR1310 currently does not support repeater mode. I think that it allows you to configure the BR1310 as a repeater, but you may experience problems.
