FLEXCONNECT CLIENTS CANNOT PING WIRELESS CLIENTS AFTER UPGRADE TO 8.0.121
I'm having issues on our flexconnect AP's wherein wireless clients cannot ping each other. I already checked the p2p settings on the wlan and it is disabled. These clients can ping their gateway ip's. Our branches have a flat network with a Router on stick setup. Wireless clients on our branches can successfully access resources in our HO. We are using same ssid with HO and BO. PLease see below SAmple output of a flexconnect client
(Cisco Controller) >show client detail 2c:d0:5a:41:b7:70
Client MAC Address............................... 2c:d0:5a:41:b7:70
Client Username ................................. N/A
AP MAC Address................................... 1c:de:a7:09:d9:60
AP Name.......................................... PAL_AP01
AP radio slot Id................................. 0
Client State..................................... Associated
Client User Group................................
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
Wireless LAN Network Name (SSID)................. corp_wifi
Wireless LAN Profile Name........................ corp_wifi
Hotspot (802.11u)................................ Not Supported
BSSID............................................ 1c:de:a7:09:d9:60
Connected For ................................... 1586 secs
Channel.......................................... 11
IP Address....................................... 192.168.160.159
Gateway Address.................................. Unknown
Netmask.......................................... Unknown
Association Id................................... 0
Authentication Algorithm......................... Open System
Reason Code...................................... 1
Status Code...................................... 0
--More-- or (q)uit
Session Timeout.................................. 0
Client CCX version............................... 1
QoS Level........................................ Silver
Avg data Rate.................................... 0
Burst data Rate.................................. 0
Avg Real time data Rate.......................... 0
Burst Real Time data Rate........................ 0
802.1P Priority Tag.............................. disabled
CTS Security Group Tag........................... Not Applicable
KTS CAC Capability............................... No
WMM Support...................................... Enabled
  APSD ACs.......................................  BK  BE  VI  VO
Power Save....................................... OFF
Current Rate..................................... m15
Supported Rates.................................. 6.0,9.0,12.0,18.0,24.0,36.0,
    ............................................. 48.0,54.0
Mobility State................................... Local
Mobility Move Count.............................. 0
Security Policy Completed........................ Yes
Policy Manager State............................. RUN
Policy Manager Rule Created...................... Yes
Audit Session ID................................. c0a8ed02000030d1574f7237
AAA Role Type.................................... none
--More-- or (q)uit
Local Policy Applied............................. none
IPv4 ACL Name.................................... none
FlexConnect ACL Applied Status................... Unavailable
IPv4 ACL Applied Status.......................... Unavailable
IPv6 ACL Name.................................... none
IPv6 ACL Applied Status.......................... Unavailable
Layer2 ACL Name.................................. none
Layer2 ACL Applied Status........................ Unavailable
Client Type...................................... SimpleIP
mDNS Status...................................... Disabled
mDNS Profile Name................................ none
No. of mDNS Services Advertised.................. 0
Policy Type...................................... WPA2
Authentication Key Management.................... PSK
Encryption Cipher................................ CCMP (AES)
Protected Management Frame ...................... No
Management Frame Protection...................... No
EAP Type......................................... Unknown
FlexConnect Data Switching....................... Local
FlexConnect Dhcp Status.......................... Local
FlexConnect Vlan Based Central Switching......... No
FlexConnect Authentication....................... Central
FlexConnect Central Association.................. No
--More-- or (q)uit
Quarantine VLAN.................................. 0
Access VLAN...................................... 1
Local Bridging VLAN.............................. 237
Client Capabilities:
      CF Pollable................................ Not implemented
      CF Poll Request............................ Not implemented
      Short Preamble............................. Implemented
      PBCC....................................... Not implemented
      Channel Agility............................ Not implemented
      Listen Interval............................ 5
      Fast BSS Transition........................ Not implemented
Client Wifi Direct Capabilities:
      WFD capable................................ No
      Manged WFD capable......................... No
      Cross Connection Capable................... No
      Support Concurrent Operation............... No
Fast BSS Transition Details:
Client Statistics:
      Number of Bytes Received................... 15732561
      Number of Bytes Sent....................... 119625687
      Total Number of Bytes Sent................. 119625687
      Total Number of Bytes Recv................. 15732561
      Number of Bytes Sent (last 90s)............ 40594
--More-- or (q)uit
      Number of Bytes Recv (last 90s)............ 249624
      Number of Packets Received................. 63975
      Number of Packets Sent..................... 95694
      Number of Interim-Update Sent.............. 0
      Number of EAP Id Request Msg Timeouts...... 0
      Number of EAP Id Request Msg Failures...... 0
      Number of EAP Request Msg Timeouts......... 0
      Number of EAP Request Msg Failures......... 0
      Number of EAP Key Msg Timeouts............. 0
      Number of EAP Key Msg Failures............. 0
      Number of Data Retries..................... 33036
      Number of RTS Retries...................... 0
      Number of Duplicate Received Packets....... 3
      Number of Decrypt Failed Packets........... 0
      Number of Mic Failured Packets............. 0
      Number of Mic Missing Packets.............. 0
      Number of RA Packets Dropped............... 0
      Number of Policy Errors.................... 0
      Radio Signal Strength Indicator............ -50 dBm
      Signal to Noise Ratio...................... 51 dB
Client Rate Limiting Statistics:
      Number of Data Packets Received............ 0
      Number of Data Rx Packets Dropped.......... 0
--More-- or (q)uit
      Number of Data Bytes Received.............. 0
      Number of Data Rx Bytes Dropped............ 0
      Number of Realtime Packets Received........ 0
      Number of Realtime Rx Packets Dropped...... 0
      Number of Realtime Bytes Received.......... 0
      Number of Realtime Rx Bytes Dropped........ 0
      Number of Data Packets Sent................ 0
      Number of Data Tx Packets Dropped.......... 0
      Number of Data Bytes Sent.................. 0
      Number of Data Tx Bytes Dropped............ 0
      Number of Realtime Packets Sent............ 0
      Number of Realtime Tx Packets Dropped...... 0
      Number of Realtime Bytes Sent.............. 0
      Number of Realtime Tx Bytes Dropped........ 0
Nearby AP Statistics:
      PAL_AP01(slot 0)
        antenna0: 136 secs ago................... -51 dBm
        antenna1: 136 secs ago................... -57 dBm
DNS Server details:
      DNS server IP ............................. 0.0.0.0
Assisted Roaming Prediction List details:
--More-- or (q)uit
 Client Dhcp Required:     False
Allowed (URL)IP Addresses
AVC Profile Name: ............................... none
Leo Laohoo
I don't know where the decision to upgrade to 8.0.121.0 came from but Cisco has removed all links to download this particular version due stability issue.  Upgrade to 8.0.133.0 and see if the problem sorts itself out.
We upgraded to 8.0.121 from 7.4.121 to support our new AP's (1700)
