FN74035 : ....APs may not detect radar signals....
Mark Elsen
                   - FYI :  https://www.cisco.com/c/en/us/support/docs/field-notices/740/fn74035.html
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
And they have an Interim Workaround: Disable DFS channels. And with a loud collision, our Chanel plan implodes …
M02@rt37
Thanks @Mark Elsen !
Best regards
Leo Laohoo
Thanks @Mark Elsen
This FN is going into my LIST of Bug IDs exclusive to the 2800/3800/4800/1560.
Old 2700/3700 and Catalyst 9k are not affected.
IMPORTANT:
Make sure to thoroughly TEST the recommended APSP &/or Engineering Special release before committing the rest of the APs.  It is of no use if the recommended APSP will break other stuff.
