Frequency problems wgb340s
palm
Community Member
I'm have some problems regarding my WGB340 series. In able to communicate with other radios I have to change the frequency time and again. If I lock the bridge to a specific frequency, the wgb will loose it connection, and I must change to a different freq. for it to work again. What might be the problem.
ggrhodkinson
Community Member
It worth just checking the cisco release note for the bridge to see if your problem is common and there may be a firmware fix.
Are the other Radios Aironet ?
SNSL
