FSR in an Infrastructure mode environment
sawosankung
In a WLAN where WPA+PSK authentication is used with AES encryption, between clients and AP, is a WDS still required for FSR roaming between APs given that the APs are in the same subnet/VLAN ?
Stephen Rodriguez
WDS is not required for a PSK WLAN, it is only relevant to a 802.1x/CCKM  WLAN.
With a PSK, every AP has the key, so no need for a central management.
In 802.1x/CCKM, since the key is derived, we have a need for the central management, and that is what the WDS master gives us.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Yes, I couldn't imagine otherwise. Just wanted to make sure
Thanks very much anyway.
Vinay Sharma
Level 7
Level 7
Hello Sankung,
Please mark the Question as Answered, if the provided information by Stephen is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
