Guest WiFi with WLC 2504
Troy Keyes
Good Morning,
     I'm attempting to setup a Guest WiFi. There is already a "Guest" SSID on the WLC. I believe it's a direct copy of the internal private SSID. Both SSID's are on the "management" interface.  I'm trying to separate it from the internal network. I want it on a complete different subnet. Can someone help me do this? After multiple attempts I keep getting port configuration error.
Troy
Scott Fella
First you need to review the guide to create dynamic interfaces and validate the switchport trunk information is correct. Then you create a new wlan and map that to a dynamic interface.
Here are some guides:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/68100-wlan-controllers-vlans.html
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/wlans.html
-Scott
